Question About Suzuki Savage
IaMbRoKeNoW
06-30-2005, 04:55 PM
Hello All,
I've posted a few times and have gotten a lot of help...hope I can get some good answers again. I have a 2002 Suzuki Savage and am having a small problem with my rear running lights. To be exact they dont work...only when I am using a turn signal. I did not get a manual when I got the bike and I refuse to go to the mechanics in my area because they rape you so horribly with their prices. I am thinking it might be a relay or maybe a fuse or something. Unfortunately I dont know where they are located and I am not confident enough to go rooting around and potentially messing something up. So if you all could either give me a sight where I can view/download a manual or tell me the location of the fuses on a Savage I would be VERY thankful for any help. Thanks in advance!
speediva
06-30-2005, 09:34 PM
The rear "turnsignals" don't function as running lights like the front "turnsignals". At least that is how MOST bikes work. I hope that is what you meant...
chubster2003
06-30-2005, 10:43 PM
your right its prolly a relay or a fuse... as far as finding them.. dont know.. just did a google search and found they are under the seat??? haha.. sorry.. my CBR is easy.. there is a little cover on the right upper faring that says "fuses" hahaha... anyway good luck
IaMbRoKeNoW
07-01-2005, 12:27 AM
under the seat eh? firgures it has to be something like that...thanks :) and on my bike my back yellow running lights double as my blinkers like my front lights...the blinkers still work...but the running lights are always off unless as i said...i am using my blinkers.
aussieidiot
07-01-2005, 03:21 PM
might be as simple as the globes.
always assume the easiest.
as they are a running light and a blinker they may have a twin filament and three contacts. i'm having a guess here because in OZ we don't have that setup with ruuning lights.
if its a relay steup to control the running and blinker configuration, then it will be a single filament and a single fuse. there will be a relay with a problem. i'll try and figure out how they'd do it and get back to you (ps i'm a sparky)
pasquot
07-06-2005, 08:46 AM
Hi, If you haven't already done so, check 2 websites for savages.
www.heise.workstations,de/ls650/fragen/ls650-fragen.html
www.suzukisavage.com
The 1st one is the one with the most information. If that website doesn't work, do a search under suzuki savage forums. Most people read both forums so if you can't find the heise site ask on the suzukisavage site.
NaKeDZX
07-06-2005, 09:56 AM
Saturn gave you the answer. The rear signals aren't wired as running lights from the factory. You could adapt some 3 wire signals, but the stockers just aren't wired that way.
