MKIV NonTurbo Tranny on a 2JZGTE motor
labud1971
06-29-2005, 10:10 AM
My question is, will a MKIV Non turbo SUpra Five speed transmission mate up cleanly to a 2JZGTE twin turbo motor?
My contacts in Japan state that it would, however the "experts" in the US say that it won't?
I understand the non turbo 5 speed won't hold up to more than 300hp, my motor is going to stay stock for the time being.
Any expert advice would be greatly appreciated.
thanks! :sunglasse
flyinMKIV
06-29-2005, 01:38 PM
Yes, the 5 speed n/a tranny will hold but it depends on what your planning on doing with the car.
The transmission will hold up to about 400hp and after that, it's just a matter of time before it gives. could be a month, could be years, who knows. Those manual trannys were not designed to take boosted applications, hence they will not hold for long.
I would suggest finding a good auto tranny and building that since it basically will hold to about the same if the tranny is stock. or lok for a 6 speed tranny but they are hard to come by in good shape and on top of that they are rather expensive.
labud1971
06-29-2005, 07:17 PM
Thanks very much for the clarification. I'm dropping the JDM Aristo 2JZGTE motor in a 72 Datsun 240Z. I only plan on pushing around 330-350hp for the time being. I'm sure the power to weight ratio will provide awesome performance in my 1900lb 240Z. I'll buy time until I come across a decent 6speed Getrag before putting on the T51R turbo kit :grinno:
thanks again :biggrin:
flyinMKIV
07-01-2005, 12:25 PM
If your planning to push only that much, you really don't need to waste money on a turbo kit. The stock twins will push that easily and efficiently. I'd stick with them for the time being. You really only need a full exhaust and a front mount with 18 psi to push 350hp. But that's my oppinion. Hope it doesn't give you too many problems.
labud1971
07-01-2005, 07:48 PM
That's my plan for the short term, just want the motor planted so I can jet around until I find a 6speed Getrag, then the T51R turbo setup goes on :naughty: I bought the entire turbo kit in Japan for $1500 used. I'm getting an APEXi PowerFC programmed/wired for the JZ161 ECU harness.
Future upgrades are going to be 1000cc injectors, HKS cams and other goodies.
thanks for your input
GadflyII
08-08-2005, 11:19 PM
I agree with you, though there is a guy here in Dallas that put a stock 2jzgte in his NA supra, and the killed the tranny at stock boost levels in about a month...
