Starting Problems ???
gearshift101
06-27-2005, 12:15 PM
Hello All, As you can see I'm a newbie here! Heres my problem? I have a 307 eng from a 85 delta 88 for which I installed into a 1985 GMC G15 Van. The thing is this! I took it out on the road for about an hour, just around town. It ran great, then suddenly at a light it stalled. tried to start it again, and nothing, not even a click. I then let it sit for less then 1 minute, and bingo it started, but then stalled again after a few seconds, and the same thing tried to start it and nothing. Well needless to say I got it home, with a pull chain of course. So I let it sit overnite went out in the morning turn the key and it cranked so I turned the key back to the off possition and tried to start it again, and nothing. the battery gives me a reading of 12.5V so it's not power, I'm sure it's a short somewhere but can't pin-point it. any suggestions will be greatful.
My 1st thought: is to jump the starter then if it starts, I would have narrowed it down to the ignition switch??, ignition lock cylinder?? or the accuator arm?? and if it don't crank it could be the stater switch (solenoid) I hope i'm on the right track, what do you think! what else should I check, I know the spark plug wires are in bad shape had to tape some of the insulation, replaced fuel filter, PCV , and spark Plugs.
Thanks in advance!
Al
auto trainy
06-27-2005, 07:40 PM
I would check for a loose connection for the ignition,firewall,distributor,any connector or wire that was moved or disconnected and reconnected during the changeover. good luck
gearshift101
06-28-2005, 04:40 PM
The ignition problem has been solved. replaced the dist cap, rotor, and new wires. the old wires where shot, cracked etc.
