1997 Ford Escort Headlight assy R+R
19escort97
06-27-2005, 07:43 AM
I have a cracked lense on my driver side headlamp and I need to replace the whole unit. Problem is I can't figure out how to remove the botom fasteners.
I have the replacement unit & I can see where they are, but as far as I can figure, I need to remove the bumper to get to them.
I'm hoping that I'm wrong there & I seek the knowledge of the forum for help.
How do I remove & replace the left side headlamp assembly on a 1997 Ford Escort LX (not coupe or ZX2)
TIA.
TIA.
Davescort97
06-27-2005, 03:31 PM
Yeah. The front bumper cover has to come off to get to the bottom fasteners. It's not too hard to get it pulled. Where the hood meets the grill there are 3 screws that need to go. On the bottom, opposite the license plate area there are 4 nuts or bolts that need to go. I can't remember which. The last part is a little bit trickier. The inner fender well has to come off in the front. It helps to block it with a piece of wood before you go any further. Where the bumper cover meets the fender just inside the wheel well there is a single bolt up and down that has to come out. Then, just below the marker light there is a straight line about 3 inches long where the bumper cover meets the fender in front. There's two 14mm bolts going perpendicular through the 3 inch line on the inside. You'll need a ratchet with a 10 inch extension and a 14mm socket to get to it. It's not a big job. Good luck.
