92 f150 ac problem
jcougar88
06-25-2005, 03:33 PM
I have a 92 f-150 300 6cyl with factory a/c. Just flushed system out, replaced orifice and drier, and recharged. low side gauge shows 100 psi/high side shows 210psi. At idle, blows warm air. Higher the rpms, the colder the air gets. Can anyone help me determine what's wrong? Running r-12 still, and think its compressor, because at higher rpm, low side drops to about 60. Not overcharged, only used 42 ounces of r-12(recommended for this vehicle). need to find problem. Really hot in Louisiana. Thanks
way2old
06-25-2005, 05:45 PM
Have you checked the condensor to be sure it is clean? Sounds to me like the condensor is either plugged with dirt, or plugged internally.
jcougar88
06-26-2005, 12:27 PM
i flushed out the entire system. everything seemed to flow through nicely. Other than that, I don't know how else to check the condensor. Thanks.
way2old
06-26-2005, 01:33 PM
Do you have a fan clutch? If it is not operating properly, this may cause the concern where the condensor is not cooling properlly. Also use a water hose to clean all the debris from the cooling fins of condensor.
