97 expedition sunroof
jaulette
06-24-2005, 11:23 PM
Anyone know if you can close the sunroof manually...Stuck in the open position a few inches.
Thanks
Thanks
rivguy
06-30-2005, 03:10 PM
That Sucks - There Is A Motor Access And You Can Remove The Motor And Move The Track Manualy However, It's Rare To Have A Bad Motor Normaly The Track Itself Is Broken And Then Your "sol"
jaulette
07-05-2005, 12:42 PM
Tks for the info, i'll look for the motor...
jaulette
07-28-2005, 01:59 AM
Thanks
Had to take the headliner apart to find the motor located just behind the frame of the sunroof. Wasn't too hard. located part number, jotted it down to look for in junkyard, or elsewhere. And located the manual crank to close the sunroof , right by the motor. Closed it with an allen wrench. No more plastic and cardboard..lol, works fine now closed.
Thanks
jaulette
07-28-2005, 02:11 AM
Thanks
Had to take the headliner apart to get to the motor, wasn't that hard. Located motor just behind the frame of the sunroof. Jotted down the part number for the motor and will try to locate in junkyard or elewhere.In the meantime I located the manual crank for the sunroof near the motor, and closed it with an allen wrench. So no more plastic and cardboard to close off sunroof. All closed up and seated just right...hope this helps someone else
Thanks
