Boss Mustang help/info required
danowat
06-24-2005, 06:15 PM
Hey All,
I need some help to find some info on a 1970 Boss Mustang, as I understand it, these engines had blue engine blocks.
I would like to know what "sort" of blue this was, and also how far this colour extended, i.e. was the sump and gearbox also blue or were they a different colour.
Cheers
Dan.
CrossRamZ28
06-24-2005, 06:32 PM
Model Master makes "Ford Engine Blue" which is almost an exact match.
As far as what was painted Blue, I'm not too sure. I've seen many Mustang engines and it was hard to tell what was factory stock and what was modified.
stang351
06-24-2005, 06:36 PM
I know the block, the heads, the water pump were blue, but i dont know about the oil pan, it is either flat black or blue
griffin-gt40
06-24-2005, 08:22 PM
Ford engine blue is the correct colour. As far as I know Testors is the only "model paint" with that colour. The block, heads and water pump were painted blue. The oilpan and bellhousing back are aluminum or steel coloured. I've also seen the stock aircleaner painted engine colour but I'm not sure if this is factory stock or just for looks.
David
danowat
06-25-2005, 02:33 AM
Many thanks guys, a great help
Dan.
JTRACING
06-25-2005, 04:51 AM
im not sure which engine you mean, the 302 or 429?
here is the 302ci.
http://www.arcor.de/palb/alben/01/1904101/1024_3561633830313863.jpg
and heres the 429ci.
http://www.arcor.de/palb/alben/01/1904101/1024_6661343837333938.jpg
