96 Lumina A/c Bypass
sparrow_21
06-24-2005, 12:24 AM
Can you bypass the a/c pulley on a 96 lumina 3.1? It doesn't seem to be possible with a shorter belt because I;m pretty sure that I would also bypass the water pump pulley and that would not be good. Unless I'm looking at the pulley arrangement wrong?
jeffcoslacker
06-24-2005, 09:55 AM
They pretty much make them so it's not practical to try to do what you are contemplating.
Is your compressor bearing bad, or you just trying to eliminate the A/C (and if so, are you NUTZ?)
sparrow_21
06-24-2005, 03:41 PM
bearing is toast
jeffcoslacker
06-24-2005, 06:31 PM
bearing is toast
I've gotton those compressors from junkyards as low as $40. Put in new o-rings, and it'll probably work fine once evac'd and charged, unless the compressor guts self-destructed at one time also.
