91 Pathfinder ???
paulsenior
06-23-2005, 01:57 PM
Just trying to get smart I am looking at buying a 1991 pathfinder V6 4x4 with 190K for 1500$. What I would like to know is about the front suspension. it seems to sit really low like there is a olny two fingers space between the tire and the fender flare. is this normal or a sign of a costly repair??? I have seen a few pathfinders and most look the same. what would it take to raise the front up a little???
timmytim
06-26-2005, 02:21 PM
the front end uses torsion bars for suspension, and they can be adjusted by turning a nut on each side, to lower or raise the vehicle. however if its that low, and bumpy when driving, thay may be worn and need to be replaced, which is costly.
paulsenior
06-26-2005, 08:08 PM
its not bumpy really it just sits low. what is involved with adjusting the nut??? what signs should I look for which may lead to needing a replacement???
