goes up and down at idle...
YZ125rider21
06-23-2005, 12:21 AM
I just finally got a new timing belt put on and got my timing fixed right...now at idle my car RPM's goes from 800 to 1200 back down to 800 constantly...check the main vacums make sure not a leak and still cant figure this one out...i know i need a new o2 sensor but i gurrantee that aint the problem...any ever have this problem or knows what it could be please respond thanks....
ef four door
06-23-2005, 12:42 AM
try bleeding your coolant...on a zc the bleeder screw is on the back of the head on the thermostat housing.
YZ125rider21
06-23-2005, 12:52 AM
that would cause my idle to go up and down?
AudioGuy93DelSol
06-23-2005, 12:22 PM
How long was your car sitting without being started? Same thing happened to me. I put some Lucas fuel cleaner in my tank and hasn't happened since.
Slick_Rick
08-30-2005, 10:03 PM
try to make sure u got all ur vacume lines in stalled in the right place
civickiller
08-31-2005, 04:52 AM
air in your cooling system will cause surging till its all aired out
dwbailey
08-31-2005, 07:46 AM
If bleeding the cooling system doesn't fix it, it will be the infamous idle air control valve most likely. :crying:
civickiller
08-31-2005, 04:31 PM
it could be the fitv.
heres the list i would go over step by step
1. bleed air out of cooling system
2. check all vacuum hoses for leaks
3. take off iacv and clean the little screen
4. take off fitv cap and screw in the center piece
Jags28
09-03-2005, 05:33 PM
Do you bleed the coolent when the motor is hot and running? Jags
