cleaning injectors
88camaroproject
06-21-2005, 01:13 PM
how would i clean my fuel injectors while i have them out of the car? oh and any one know where the fuel filter on my camaro. i havnt looked but i would like to know before i look.
-thanks, tom
Rally Sport
06-21-2005, 01:17 PM
Well my fuel filter was on the left side of the Camaro, like behind the driver side under the car ofcourse. It shouldnt be that hard to find, it's pretty big.
89IROC&RS
06-22-2005, 05:35 PM
the fuel filter is on the driver side of the undercarrage, about a foot in front of your left rear tire. you need a 5/8 and 11/16 wrench to get it off i think.
To clean your injectors, i would reinstall them, and get a can of 44k from your dealership. Its a fuel additive that cleans your entire fuel system.
88camaroproject
06-22-2005, 06:41 PM
ok i shall do that, thanks....wait is gas going to squirt out when i take the fuel filter off? if so what should i do
skibum1111
06-22-2005, 07:59 PM
If your car is fuel injected, you have to depressurize the fuel system first, pull the fuel pump fuse and try to start the car, it might start, if it does let it run until it quits, usually 2-3 seconds at the most, then be prepared to catch some gas when you take the filter off.
Rally Sport
06-22-2005, 08:09 PM
Or if you cant find the fuse like I did, take off the fuel pump relay which is wayyyyy up near the gas tank, then do what he said.
Xenostalgia
06-22-2005, 09:18 PM
if you just wanna let it run and be dumb (like me...) it leaks like 1/4 a gallon of gas before its done.
ct91rs
06-22-2005, 09:25 PM
the f/p relay should be located under the hood on the drivers side, rear engine area, on the upper part of the firewall.
under the rear of the car, up and in front of the tank. there is a connection that you could separate, and this would cut the power to the pump. but it may not come apart easily.
88camaroproject
06-22-2005, 09:27 PM
my system is not pressureized. my gas lines arent even connected, wait no i just got those connected tonight, but they stil arent pressurized, so will gas still come out? oh and this is my fuel filter right ---> http://files.automotiveforums.com/gallery/watermark.php?file=/503/320275fuelfilter.jpg
ct91rs
06-22-2005, 09:32 PM
depends, it won't spray out, but if there's anything in the line, it's gonna come out
Xenostalgia
yes and yes gas will still come out not much tho
88camaroproject
06-22-2005, 09:34 PM
ok well i guess ill replace that considering its prob never been replaced
Xenostalgia
06-22-2005, 09:44 PM
yeah thats bad.... :/ i heard like every 50-60k you should replace it
88camaroproject
06-22-2005, 09:48 PM
lol i more then doubled that, well that i know of. i dont know if any of the many previous owners did but i will just cause i got a new engine and it better work great for a while
Rally Sport
06-22-2005, 09:54 PM
True, if you dont replace also it can mess up your pump, making crap get in there.
Genopsyde
06-22-2005, 10:23 PM
gas goes thru the pump before the filter, not after.
ct91rs
06-30-2005, 09:32 PM
Rally Sport 92 is right if he's referring to the strainer that goes on the end of the pump in the tank, it's another smaller filter, but normally you would only change it if you're putting in a new pump
Viper_Storm
06-30-2005, 09:38 PM
lol plus that shit burns like hell
J.Cutta
07-04-2005, 08:34 AM
when changing the fuel filter dont let gas run down your arms. That shit will itch
Rally Sport
07-04-2005, 02:48 PM
..Maybe you got really sensitive skin because that doesnt happen to me.
tom3
07-04-2005, 06:46 PM
The injectors in your 88, if like mine, are the Multec injectors and they do have problems. If yours are not working right, using FI cleaner might make the problem worse. I guess the electrical windings are not made to withstand the cleaner and you'll have problems, or worse problems afterwards.
