spark arcing problems
speedy15464
06-21-2005, 04:03 AM
I have a 95Z28 camaro recently i noticed some arcing in the wires and coil. so i replaced the wires and coil but the problem remains . so i changed the opti, plugs, wires, coil and now its running really rich did some scans for codes but got nothing . does anyone have any ideas about this problem or has anyone ever had this problem . getting really frustrated here im spending money and its getting me nowhere .
ct91rs
06-21-2005, 10:12 AM
bad fuel pressure regulator?
speedy15464
06-21-2005, 01:20 PM
would a bad fuel pressure regulator make it arc sparks only on cetain cylinders ?
thanks ill check the regulator
ct91rs
06-21-2005, 09:13 PM
it wouldn't be related to the arcing problem
the f/p regulator is probably fine. I just mentioned it, because if the diaphram is ripped, it would run rich, and the only thing that might send a code is the O2 sensor.
where exactly do you see the arc occur? from the end of the plug wire to the block?
speedy15464
06-22-2005, 03:34 AM
The arc is at the plug itself near the glass part and around the coil near the housing . i replaced the plugs thinking maybe the wasnt anygood but i get the same results
