wheel bearing sensor harness/abs/trac/rear brakes
fishendude
06-20-2005, 10:26 PM
I found my front passenger wheel bearing harness dangling under this car with the wires exposed----- but not to bare wire-could this be why my abs /trac off light appear.I replaced that bearing with no luck on removing the lights.Before I replaced the bearing I would get the abs/trac light only after a couple miles--now it is all the time.Is the harness that the bearing plugs into removable? Could it be the harness causing this problem? I just had the driver front bearing replaced three weeks ago------Also would worn brake pads on the rear cause these light to appear?
fishendude
06-21-2005, 05:04 AM
stressing
skibum1111
06-21-2005, 07:28 PM
The harness is replacable, it was a dealer only part when i replaced mine 5 years ago. A common problem with them is they get full of water and crud when you drive, and the wiring rots out of them, leaving the insulation and the appearance of a good connection. I had the dealer diagnose mine, then bought the harnesses and replaced them, no more abs light...
bigdad6714
07-08-2005, 04:03 PM
Hey fishindude , did you reset the computer , if not unplug the neg. battery cable for a few minutes and reconnect. i had the same problem .
xeroinfinity
07-28-2005, 11:27 AM
NOTE these should be replaced in PAIRS. That means change BOTH at the same time/day!If not you'll just go back and forth, but wires dangling is not good at all.
I've had my wheel bearing/hub unit on my 99' grand am replaced three times, and it was like $1100 each time. The first two it was the bearing squeealing.Dealer said it's commen on 99's', and of course the 1 yr warrnty was up by only a month or so( got screwwed)). Then I had the ABS and Trac off lights come on and it was the wheel speed sensor. And another $1000.
I could've done it but I have nowhere to do the work properly. I only had my car 3 yrs, but I do DRIVE it. Remember their all disposable, why else would they make soo many:)
