2002 Ranger Electric Window Working Sometimes
robcaryh
06-19-2005, 10:53 PM
Howdy all
I have a 2002 Ranger with electric windows.
The passenger side is working intermittently but mostly not.
I will roll it down it may go down all the way,maybe 3 inches.
Then i hit the button to put it down more or up and it wont move.
I might go out an hour later and hit the button and it works again,but the same way.
Is this the motor most likely or the switch? I tried banging on the door and switch while pushing the switch hoping to indicate a loose connection but nothing different happens. Of course it is 2 months out of warranty now.
jimbago
08-26-2005, 04:48 PM
I came upon your post when I searched Google for the same problem. I threw away $33 at the local ford dealer replacing the switch. (Electrical parts can not be returned.) After disassembling the door, I found that the window worked when the motor was pressured towards the interior. (It could be misalignment or a faulty ground connection.) I made an appropriate size piece of 2" thick lumber and wedged it between the motor and the outside of the door. So far, so good.
Howdy all
