Drop it 2" on standard strurs?
Soldier456
06-18-2005, 05:59 PM
If i drop my civic 2" with lowering springs, on standard struts and standard shocks, will it be ok or is this a bad idea. IF its ok then thats GREAT! cos i aint got loadsa money to spend
TheSilentChamber
06-18-2005, 10:38 PM
I'v seen people ride stock ones on 3" drop for couple years with no problems. Has alot to do with your area and driving conditions and stuff. Dont skimp out on suspension, and spelling mistakes on the topic make you look like a monkey fuck.
BullShifter
06-19-2005, 02:10 PM
Don't do it, you car will ride like shit and the struts will only last a short time. Most of the time you don't feel a strut going bad because it gradually goes bad.
Take it from some one who knows suspension.
CR50HC
06-19-2005, 04:39 PM
best to do the suspension right the first time instead of half assing it the first time around. No offense but,You'll end up replacing those stock struts that are probably already worn out. If you're on a budget, look into Tokico blues. You can get a spring/strut kit for around 300.00 plus shipping. Add installation (unless you have the know how) and an alignment (consider a camber kit as well) and you'll have a proper suspension for daily driving as well as "spirited" driving. You also won't go broke and will minimize you car's downtime.
Riceboy891
06-21-2005, 06:03 AM
If you put it in yourself take your time and make sure you do it right because i know a guy that just put new shocks/springs in his integra, he put the washers and bushings on in the wrong order. It held together for a while, but then he hit a bump and the rod of the shock shot through hs hood. Just thought that was something worth mentioning.
rowitha
06-24-2005, 09:33 AM
i looked at your pics and i judt thought id let you know i love the placement of that shift light its hot
BullShifter
06-26-2005, 12:38 AM
:bigthumb:
