starting problem 1995 intrepid
TINA BERGHOLM
06-16-2005, 06:09 PM
I Bought This Car About 4 Months Ago. A Couple Days After I Got It, It Started To Have Some Starting Problems. When I Try To Start It, There Is Nothing. I Can Sit There For 10 Seconds And Sometimes It Will Start Up. Other Times I Have To Try Several Times. The Last Couple Days It Seems To Be Getting Worse. It Doesn't Make Any Clicking Noise Or Anything, Just Nothing Happens. Sometimes It Takes 4 Or 5 Tries For It To Connect And Then It Starts With No Problems At All. As You Can Tell I Know Nothing Much About Cars, So If Anyone Has Any Ideas I Would Appreciate It. Thanks
theFREAKnasty82
06-17-2005, 01:42 AM
Sounds like you have a faulty crankshaft position sensor. Do you have a check engine light that comes on as well?
TINA BERGHOLM
06-17-2005, 04:54 PM
Thanks For Responding. No, The Check Engine Light Does Not Come On. I Have Driven It Several Times Today, And It Didn't Do It Once. Thats How It Seems To Work. It Acts Up Then It Seems To Be Fine. When I Turn It To Start, It Has All Power, Just Won't Start. Thanks Again
