90 integra
neednewcar
06-15-2005, 10:05 AM
I have a 90 integra ls 5 spd...recently i had my motor mounts snap off the block causing it to crack...i had a b18a1 engine in it, now i have to find something new...if i keep the same tranny do I have to buy the same engine or would i be able to use a b16a1 also?
teg94
06-15-2005, 10:31 AM
u can keep ur tranny
97integrals
06-15-2005, 10:38 AM
Yes you can keep your same tranny, but pairing a b16 with an ls tranny is about the worst combination you can get. The b16 already has very little low-end torque and the long gears of the ls tranny make this pretty much unbearable. I definitely would not recommend doing this.
teg94
06-15-2005, 10:54 AM
Exactly, ls trannies shift into lower rpm's rather than a tranny off an b18c or b16a which has shorter gears to keep the rpms higher because thats where their power is.
djkarlkani
06-15-2005, 10:20 PM
ya i second that just buy the whole complete engine, ecu tranny engine. a b16a sir II will drop right in and it only cost about 1000. ANd your old tranny is pretty much trash. all non-vtec trannys are geared for driving your kids to soccer pratice. Not for street raceing like the v-tec's trannys.
Ace$nyper
06-15-2005, 10:26 PM
best quote EVER
best quote EVER
teg94
06-15-2005, 10:39 PM
hahahahaaha
