Changing TPS - How to clear code?
Summett
06-07-2005, 09:35 PM
I have read up on what i think is a solution to my problem. I have a '99 GC Ltd & I get a surge in rpm from about 600 to 1200 frequently during idle, and also occasionally while driving.
To start i'm looking to change the tps, but understand if i check it or change it, that the "diagnostic codes need to be cleared" before i restart the engine.
How do i clear the diagnostic code? It says to use a scan tool, but i don't have that tool. Do i unplug the battery terminal, or will the computer just reset it? If i unplug the battery, am i causing anything else to go wrong?
Thanks for the help.
The_Penguin
06-09-2005, 08:53 AM
If I remember correctly, if you don't have a scan tool to reset the code, the code will reset after x number of starts. 50 seems to ring a bell....
cbftbl87
06-15-2005, 02:42 PM
Just disconnect the battery and reconnect.
