resetting the ecu and engine check light
vietfella
04-16-2002, 11:49 PM
I need help and I was wondering if anyone could help me... i have a 2001 accord lx. i recently installed an AEM CAI and like my gas mileage has been horrible. So i read that i should reset my ECU. I resetted it by finding the ECU fuse which is on the left fuse next to the driver side door. I did the usual unplug and replug then idle for about 5 mins. But after i did that my engine check light is always on. Anyone have any suggestions??
HONDA_99
04-17-2002, 07:09 AM
wrong fuse.
find fuse that labled CLOCK BACK-UP, it should be on passenger side and if i'm not mistaking it's fuse #13.
92Accord92
04-17-2002, 10:07 AM
Just Unplug your Battery for 5 minutes.
That should do the trick..
92Accord92
vietfella
04-17-2002, 01:45 PM
thanks for the advice..disconnecting the battery worked..:D
92Accord92
04-17-2002, 01:49 PM
No Problem....:sun:
M898
04-18-2002, 09:17 AM
Can someone please tell me why is there is a need to reset the ECU
I am finding that my idle speed when I have the air-cond on and trans in Drive and car stationary is too low - I feel vibrations in the car
would resetting my ECU have any effect...and why should it ?
thanks
92Accord92
04-18-2002, 09:25 AM
Well when you change your Intake from the stock boxxy thing to a short ram or a CAI. It changes the amount of air that is taken into the engine.
The computer has a memory of how much air is going through it, and when you change the amount you have to reset the computer so it can register another amount...
Why?? I don't know...its just the way it is...
92Accord92
HONDA_99
04-18-2002, 01:24 PM
i think you need to do a basic tune-up, thats all.
