1997 Grand Am Low Coolant Light
JonJailer
06-04-2005, 09:13 PM
Hello everyone,
I just changed the thermostat in my 1997 Grand Am, I re-connected all the hoses, and started the car, followed the instructions in my chilton manual. But the low coolant light will not go out on my dash. I think I bled the system properly. Does anyone have an idea for this fix? Maybe disconnect the battery, then re-connect.... etc???
Ridenour
06-04-2005, 11:49 PM
There should be a "reset" button in your fuse panel. It will probably be red. Press and hold it for 3 seconds. If this doesn't do it, unplug your battery for a few hours, and if that still doesn't do it, then you have a faulty coolant sensor.
JonJailer
06-05-2005, 08:22 AM
Thanks Chief, I see you respond to alot of questions. Its great to see someone who wants to provide assistance as much as you do.
Ridenour
06-05-2005, 11:23 AM
No problem - there's tons of guys on here that help out even more then me :) - that's the great thing about AF, you can post any problem, and you'll usually have a couple guys give logical input on it. Everybody's always looking for ways to help out around here.
and welcome to the forum.
skibum1111
06-05-2005, 12:04 PM
Another possiblity is the sensor float is stuck, its in the pressure tank on the side of the car. It sticks on my 95 every time it gets low, so I just replaced the tank, the switch is not replacable. Before I replaced it, i would hit the side of the tank with a wrench or maglite, just be careful not to crack the tank like i did the other night...
Knifeblade
06-05-2005, 02:49 PM
Ouch, ski, that had to hurt, sigh!!!!!!!!!
skibum1111
06-05-2005, 03:13 PM
and it was a 6cell maglite, didn't think about how hard it would have hit... at least i was able to snag one out of a wreck, and the whole thing happened in the driveway.
JonJailer
06-07-2005, 04:57 PM
Ok.. So I knocked the coolant tank around a little, also I cleaned my intake with throttle body cleaner, because I saw that the butterflys were gummed up.. now i have a check engine light. How do I reset the check engine light?
JonJailer
06-07-2005, 05:09 PM
I got the coolant light to go out, but I also decided to take care of a little rough idle problem i've got going on with som throttle body cleaner. Now i've got a check engine light on, but i think it is becuase i turned the ignition key to the start position with the IAC motor disconnected. How do I reset the light? (see thread "Rough Idle")
Sikman
06-08-2005, 10:18 AM
Tapping on the sensor also helps. Use something strong, not a finger....but also don't beat the crap out of it.
tjchicago
08-04-2011, 12:25 PM
Thanks Skibum - I actually registered specifically to thank you. Just tried all three suggestions from you and the group for the same low coolant light issue on our 2001 Grand Am - reset on panel for 3, disconnected the battery, then tapped on the tank with a small rubber mallet. Tapping worked. Thanks guys!
Tech II
08-07-2011, 08:22 PM
That red reset button is for resetting the oil monitor.....99/100 times, lightly tapping the sensor in the reservoir takes care of the problem.....
