heater control valve hookup
souphmars
06-01-2005, 08:05 PM
i have the hoses from the heater core hooked up to it, they are not the problem- does it matter how u hook up the hoses on the other side of the heater control valve- not the hoses from the heater core, but the other ones- i think 1 goes to the thermostat and the other 1 goes to the water pump- i don't think it matters, i just want to be sure- thanks
98 Ranger-
07-20-2005, 01:57 PM
Hey,
Hey, I just posted this and wonder if you know anything:
The 98 Ranger I bought always has some heat coming in. A quick diagnosis is that the heater core door is left open. I have no idea if the AC works because it's always blowing hot air.
What can I do to check this out?
Is it true they need to take the dash out to see what the problem is?
I had an estimate at $1050.00 and it will continue to be hot in the truck if that's the case!
Please let me know if you know anything about this model/problem?
Thanks,
Dan
Hey,
Thanks,
Dan
souphmars
07-20-2005, 09:44 PM
u might have a leak in the vacuum hose that goes to the heater control valve- i did and it had the same problem- the end of the hose was barely on- get u a mighty vac and troubleshoot
