fuel filter help
s10fd
05-29-2005, 09:46 PM
I have a '84 s10 blazer. I was in the process of trying to change my fuel filter. Disconnected fuel lines, etc. My Haynes manual said that there is a clamp holding the filter on, but there wasn't one. It was a cylinder that looked like you could unscrew it or pull it apart at the middle, however I didn't have any luck with that. the side of the cylinder that does not connect to the gas lines bolts directly into the bottom of the engine block,(drivers side). I thought it might be the fuel pump, but I cannot find the fuel filter anywhere else, (it was where the manual said it would be, but I cannot get it apart to see if the fuel filter is inside...
any suggestions??
BlazerLT
05-30-2005, 02:41 AM
The fuel filtre should be inside of the driver's side frame.
rlith
05-30-2005, 07:25 AM
on the older tbi's is just to the back of the throttle body on the input fuel line
BlazerLT
05-30-2005, 02:18 PM
Noted.
