1991 Taurus Wiper wierdness
Dallas_38
05-23-2005, 03:34 PM
I just purchased a 91 Taurus (it was a good deal 47K, original owner a little old lady who drove it to the beauty shop, grocery store, church, and the auto repair shop for regular servicing). The only problem is that the wipers will not shut off when the pump switch on the combination switch has been pressed. I replaced the combination switch and that remedied the problem for a whole day.
I have researched this a bit and it is most likely the Wiper Control Module (although it seems more like a bad relay to me). Can someone confirm this before I front $80 for a non-returnable dealer part?
Any help in this matter is greatly appreciated :)
fubard
05-23-2005, 06:34 PM
Considering it's a 1991 I'd give the taurus boneyard a try ( auto wreckers) I had a 1990 tearazz and whenever possible I replaced with used parts.Obviously, I'd never use used brake parts but electrical parts are fair game; switches & relays..etc.
Dallas_38
05-23-2005, 08:51 PM
Thats an idea, however I am loathe to put in someone elses electrical problems. I also hate throwing money at a problem (being the cheap SOB that I am and having already tossed $50 for the switch at it). Hopefully someone else has had this problem and can come up with a solution.
sfontain
05-24-2005, 06:44 AM
I don't understand why you would assume that every salvage yard part has problems. I agree that it's a waste to put in random parts but unless you're able to find someone here who knows for sure what the problem is, that's what you're going to have to do. If you do have a good salvage yard nearby and can't get any leads on the part, I absolutely would go in and pull whatever parts you think could cause your problem and pay next to nothing for them. Then, once you find what fixes it, if you absolutely must have a new part then go buy it from a dealer.
jmas
06-06-2005, 08:57 PM
I had a 91 Taurus with Wiper Wierdness & found the problem was caused by Cold Solder connections on the wiper control board. Its under the dash & you must open the module & resolder the connectors for the relays. The wipers worked great after that but the trans failed later & I junked the car.
