Q's about setting up the suspension
BP2K2Max
05-16-2005, 09:39 AM
i'm having a little trouble adjusting the suspension settings on my bike.
according to the owners manual, the factory suspension settings are for someone who is around 160lbs, where i'm more around 140-145. i've read the article in sportrider about suspension but i'm still a little unclear. my spring preload is adjusted at the top of my front forks and there are lines on them to use to measure. stock setting is 3 lines showing off the top of the fork. so my question is, for a lighter rider would i typically want to increase the spring force or decrease it and would it be more lines showing or fewer? also, any pointers on compression and rebound damping would be appreciate as well. thanks for the help.
-Brian.
speediva
05-16-2005, 10:10 AM
I won't tell you until you give me your bike. ;)
BP2K2Max
05-16-2005, 12:03 PM
:lol2: ha,
:grinno: never, ever, ever gonna happen, lady.
speediva
05-16-2005, 01:27 PM
Just let me ride it... a few hundred miles. I swear I'll return it! I have had my license for YEARS!!! PPPPPPPPPlease????
aussieidiot
05-16-2005, 03:08 PM
come on brian, she only wear her mesh suit!!!!!
(i'm gunna get hit soon aren't i tange)
on mine i had to get the workshop to do it properly. even brand new the adjusting screws were jammed. honda quality huh!
id say go softer for your weight. but ride it to see how you like it and only do one change at a time and write down exactly what you did as you do it in case you have to go back
NaKeDZX
05-16-2005, 06:12 PM
Get a friend to help you and take some measurements. First, top out the suspension and measure the amount of fork tube showing. Now, sit on the bike in full gear. Have a friend pull slowly down on the suspension and let it rebound slowly; measure. Now lift up on the suspension and let is settle slowly; measure. Average those 2 measurements and subtract it from your first measurement (total length). The result is your sag. You want 25-35mm of sag. (>=30 for the street, <30 for the track) Same method works for the back, but you have to measure from the axle center to a fixed location on the bike.
As for damping, I set rebound damping by pulling down on the front and releasing it. I increase rebound damping until it does not ocsilate(sp?) at the top of the stroke. Meaning it doesn't shoot up and then come down again, it just rebounds in a controlled manner to it's starting point.
Compression damping I set while riding by adjusting until a)sharp bumps don't jar my teeth loose, and b)it doesn't dive too much under braking. These 2 are a compromise you have to find. Hope this helps, just one way of doing it. YMMV.
BP2K2Max
05-16-2005, 07:20 PM
thanks guys, that helps. naked, very helpful man, thank you.
saturn, you can finish off the break in miles for me, provided you change the oil and filter, deal?
speediva
05-17-2005, 06:27 AM
Oil is EASY to do! I've never gotten to ride the new 6R, but sitting on it is pretty nice.... now if only the windscreen wasn't designed for midgets to ride behind! ;)
BP2K2Max
05-17-2005, 10:38 AM
yeah oil's a piece of cake, especially with a swingarm stand to support the bike.
and i hear ya on the windscreen, i have to duck down and lean back to see how fast i'm going, or try and see down through the outside of the screen, it's a pain, but no bike's perfect.
speediva
05-18-2005, 11:43 AM
Get the Double bubble... it is supposed to help that. ;)
NaKeDZX
05-22-2005, 09:18 AM
To answer the other question in your post; more lines showing means less preload. Less lines = more preload.
Also, you may need three people so you can have your feet on the pegs while measurements are taken. 1 guy to hold the bike, one to measure, and you to sit there and look cool in all your gear. LOL
TachiTJRS
05-31-2005, 09:58 PM
This will be lengthy but something I published a while back in my home forum. Please read guys!
Although this isn't strictly a riding technique, there's a lot of false information about the 'correct' set up for a bike's suspension.The one main thing that most of these articles miss is the most crucial - setting the sag correctly.
The sag range will be the same for everyone but some of you will find that you will need to change springs to get into that right range. Race bikes, generally, need harder setting than road bikes as they ride on smoother surfaces. Road bikes have a huge range of dips, bumps and potholes to cope with so need to set slightly softer.
Most of you will have different preload settings, thanks to your weight but all of you will need to be in the same range for your suspension to work at it's optimum range, namely it's middle third.
Without the sag set right the damping will never be able to work at it's best, as it will be trying to overcome the effects of a badly set spring. Don't forget that your pride and joy has been designed to work with a hugely varying type of rider on board. It has to cope with very heavy riders to very light riders. Aggressive riders to steady riders and all points and weights in between.
A compromise? Damned straight!
It's amazing that people will spend hundreds, even thousands of pounds on suspension components and twiddle with them all day and night but never take the time to set the sag correctly and never get the bike handling any better!
So what is sag? There are two types, Static and Loaded. Static sag is the amount the bike settles under it's own weight. Loaded sag is the amount the bike settles with a rider on board.
To check that you have the right rate of spring you will need to set both the static sag AND the loaded sag, just doing one or the other is only getting half the story.
Here's what you will need to check and set your sag.
A tape measure.
A pen and paper.
Tools to adjust the front and rear preload.
Three strong friends.
Static Sag
Setting the static sag is easier than the loaded but it will still need a set of strong hands to keep the bike off the floor while you take your measurements. Lift the back wheel of the bike off the floor by pulling the bike over on its side stand.
Now, using your tape measure, take a reading from the centre of the rear wheel spindle to a point on the tailpiece that is directly above the spindle. It will be helpful to mark that point on the tailpiece for the future reference.
Write down the measurement and we will call this reading A.
Measurement A will remain the same throughout the procedure so you only need this reading once. Now put the bike back down on it's wheels and hold it upright. You will see the bike settle under it's own weight. Measure the distance from the spindle to the tailpiece. We will call this reading B.
Subtract B from A. This is your rear static sag. Keep a note of it just in case you want to change it back. Ideally you are looking for 5-10mm on a race bike and 15-20mm on a road bike.
Either compress or loosen off the spring to get into this range. The adjuster is normally a pair of rings on top of the spring. One of them is a locking ring and the other is the adjuster. You will need a C-spanner to make the adjustment. If you don't have one then a hammer and drift will do (animal!)
Now lift the front of the bike off the floor using the same side stand method. Measure from the bottom yoke to the top of the stanchion. We will call this measurement C. Like measurement A this will remain the same through out.
Drop the bike back onto two wheels and take the reading again. We will call this D.
Subtract measurement D from C. This is your front static sag reading. Keep a note of it just in case you want to change it back. Ideally you are looking for 10-20mm on a race bike and 20-25mm on a road bike. Either compress the spring or loosen it off to get in this range. The adjuster is the bit wot pokes out the top of the forks. Use a suitable spanner or socket to adjust them.
Loaded Sag
If all is well we have managed to get with in range but this isn't the whole story. We now need to take into account your weight!
Sit on the bike and have one friend steady the front, one steady the back and the other ready to measure. Sit the bike upright. Now WITHOUT touching the front or rear brakes bounce up and down a few times in the seat and then assume your normal riding position. Measure the rear of the bike as before and we will call this measurement E.
Subtract E from A and this gives you your rear loaded sag reading. Try and get between 20-25mm on a race bike and 30-40mm on a road bike by adjusting the preload as before.
Now do the same for the front. We will call this measurement F.
Subtract F from C and try to obtain 25-35mm on a race bike and 35-50mm on a road bike.
If you can't get in these ranges for BOTH Static and Loaded then you will need to change the spring for a harder or softer one. Harder if you're outside the range and softer if you are inside the range.
