Door Panels remove ?
wheels63
05-13-2005, 06:01 PM
How do I take off the door panel off my wifes 96 Grand Am? I can`t get the window knob off, The window is off it track ,but I can`t get the window knob off,I remember taking off door panels from years ago .Gm had U shaped pins but I did not see them on this one.
Tom
Knifeblade
05-13-2005, 06:09 PM
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0e/5f/2a/0900823d800e5f2a.jsp
Start here, take your time, don't forget to unscrew the lock-knob.
wheels63
05-13-2005, 06:57 PM
Thank you for the fast reply.I got the window knob off and will get back to work on it in the morning.Made a pin remover tool out of a fork.
Tom
Ridenour
05-13-2005, 08:28 PM
...Made a pin remover tool out of a fork....
LOL - tom that is just ingenious :biggrin:
Tam - wow I see it more and more all the time - that sight is packed with tons of great info. I see it being used now just about every other thread around here. What a goldmine you found - nice work.
Knifeblade
05-13-2005, 11:38 PM
Thanks ride, it sure saves texting time, like a picture worth a 1K words, ya know?
Wheels, what an ingenious thought!!!!!!!!! Using a fork to make the pin remover!!!!!!!!! Way cool.
wheels63
05-14-2005, 10:03 AM
Ridenour and Knifeblade 03 ,That I came up with long ago or someone showed me that trick with a fork,The best thing is it works,Thanks to all that helpme with this door knob removing.The pin was just hidding real close to the widow handle.
Tom
Hoags
05-15-2005, 12:29 AM
Tom the fork is a great idea, I have a small screwdriver that I bent into hook, it works great. I know that there is a special tool for the removal of the "C" clip. Rember to take your time, the plastic pins that hold the interior panel in place can break or if you pull too hard on the panel you can crack the retaining socket for the pin, I use needlenose pliers or diagonal cutters to slowly pry the pins out. Be just as careful putting the panel back on if they are not in place and you push too hard you can actually put the pins right through the panel.
I hope this helps,
Dan
