Amount of coolant
david-b
05-12-2005, 04:26 PM
Quick QU and I cant find the answer.
How much coolant does an ESi take? Also, flushing out with a garden hose... I could hook the hose up to the little radiator cap after drained, right? Thanks
macder
05-12-2005, 06:54 PM
There is an answer to this is on vfaq. I don't really know how to post a link for vfaq since it's all frames but search around there. I think's it's something like 7.6L or something round there.
david-b
05-12-2005, 07:20 PM
Thanks. I forgot to look there. How many gallons (or how much of) would that be. Im simple and stupid
david-b
05-12-2005, 07:27 PM
Actually. thats a negative. Nothing listed as of how much.
drewh4386
05-12-2005, 07:46 PM
Close but its 7.4........not like it mattered
edit- quartz i might add
edit- quarts .......i don't know
ned032002
05-12-2005, 08:02 PM
Just under 2 gallons for the lady.
david-b
05-12-2005, 08:23 PM
^^ shutup. lol
Thanks tho. Im simple minded. Thatnks alot. Ill be upa at 6am to do it
ned032002
05-12-2005, 08:50 PM
^^ shutup. lol
Have at er that the time when shit gets done is early in the morning. Good luck. :naughty:
macder
05-12-2005, 10:01 PM
http://members.shaw.ca/costall/1000Q/answers-specifications.htm scroll down a bit and you will have your answer.
hellah fresh
05-12-2005, 10:06 PM
Its 1 gal of anti-freeze and 1 gal of water. So after u pour all your anti-freeze in use that same coolant gallon and fill it up full with water and there you go. 50/50
kjewer1
05-13-2005, 06:53 PM
This is the same thing I do. Run the car to operating temp with the cap off and the heat on to work out all the bubbles. Make sure the overflow is a little over the full line, since when that coolant contracts it will pull some from the bottle.
david-b
05-16-2005, 12:36 PM
I drained and flushed the whole system and installed the new resivior. The system only took alittle more than 1 gallon of 50/50 anti/water. The tank is filled in the middle. Ive driven it alot, (even with the heat on) and it drains alittle and fills back up then. No problem, and the car runs great.
kjewer1
05-16-2005, 10:00 PM
The block and head hold a lot of water/coolant. All you can really drain is the radiator. Head too I guess, since it will drain the block only as low as the bottom of the watre pump inlet.
