Transmission leaking??????
jsteezy1290
05-12-2005, 01:01 PM
i have a 1994 deville concours that i bought with the tranny leaking fluid bad. it starts up and runs great but wont shift into any gear. there is no check engine codes coming up. i tried to look under it but i cant tell where its coming from. it really only leaks when you start the car up and leaks pretty bad it holds a steady dripping. could it be a line to the tranny that could be bad? would that be causing it not to shift into gear? any help would be awesome
parkervess
10-01-2005, 04:52 PM
Its Most Likely Leaking From Around The CV Axels When Those Seals Go Bad It Causes A Pretty Bad Leak.
