Pontiac grand am se 98 Abs
deb789
05-12-2005, 09:33 AM
How do i disable the abs on my car?
trixtaz
05-12-2005, 03:45 PM
Disconnect the sensor which should be somewhere near the wheel.
Hoags
05-12-2005, 06:21 PM
Just curious, but why do you want to disconnect the ABS? If you de-activate the ABS you will also disconnect the Traction control.
nheuer
05-12-2005, 08:59 PM
Your not allowed to disable the ABS systems. Its illegal in all 50 states to disable them. Your not allowed to mess with safety equipment in an automobile ABS, Airbags, Seatbelts and so on. Its against federal laws.
Knifeblade
05-13-2005, 05:18 PM
Like nheuer says, I wouldn't disable ABS, all kinds of bad stuff can happen if ya do, trust us. If ya having some hassle, like a dash light coming on, erratic braking, etc., describe better, maybe we can help better.
Regards
Ridenour
05-13-2005, 09:49 PM
^ ^ Yeh deffinately. The ABS shares a circuit with the trac control, and if you were to find a way to disable it by unplugging the wheel speed sensors, it could cause VCM module to throw all sorts of shit fits, and cause messed up braking due to the brake system not being able to apply the appropiate break pressure to each wheel because the speed is unknown. Like they said, why exactly do you need to disable it? I'm sure it's a problem that can be fixed differently.
