problems with car....unknown
cerestialcivic91
05-10-2005, 09:55 PM
hey everyone.....
i just got my car on the road and i have been driving it everyday so far and i have found that every so often when i start my car that the ECU code light is on solid, the engine light is on and it wont rev past 3000rpm because its in limp mode...
does anyone know what may be causing this issue and a fix for it???
any ideas let me know as of right now i unplug the ECU for a bit and plug it back in and it seems to work fine
thanks
Mike
P.S - its a 91 Civic HB running a ZC with a PM6 ECU
EF You
05-11-2005, 12:42 AM
well, its got to be giving error codes of some sort, check those and get back to us with that
cerestialcivic91
05-11-2005, 05:26 AM
yeah its a solid light....as soon as i turn the key on and start the car the code light is solid and the engine light is on
let me know
thanks
Mike
BLU CIVIC
05-11-2005, 07:03 AM
ECU busted mabey :dunno:
4G4D Store
05-11-2005, 10:29 AM
I've never seen a solid light before. Hit me up if you need a replacement if you think that one is bad, and I'll take that one and get it chipped - he he
EF You
05-11-2005, 11:02 AM
sounds like the ECU to me
Exempt
05-11-2005, 01:57 PM
Yea I belive a solid light usually means ECU is bad... Check the plug make sure its tight... U can also unplug it for about 10 min and plug it back in and reset it... See if that helps...
