fuel problem
auctionsco
05-10-2005, 07:18 AM
Hello
this is a baffler. I recently installed timing belt without problem. Then when starting the car it ran for a few seconds then died like out of gas. I put car on level ground and it did it again. we added fuel dierctly to injectors and it ran again for a few seconds. now when fuel is added nothing happens it jst cranks. Spark is good. What do I check?
Thought it might be the gate after air filter but that seems ok. ??????
Brian R.
05-13-2005, 12:35 AM
Welcome to the AF!
Sounds like you didn't install a connection to a sensor tightly enough and it vibrated loose when the engine started. Make sure all the sensor connections you touched or moved the wires for are tight and snapped in place.
auctionsco
05-16-2005, 08:22 AM
Hello
Thanks for reply
I'm not bright regarding cars. what sensor would this be?
Is it marked/ Where located?
thanks
so much
steve
