ignition switch stuck
EZFrank
05-08-2005, 08:02 PM
I am having trouble getting my 95 Grand Am started the key got stuck in the switch and would not turn to start car so i started to move steering wheel left and right still wouldnt turn checked shifter made sure was in park and still nothing i finally got the key out but wont turn the switch i took steering column apart and i cant figure out how to pull switch out looks like some metals pieces are broken in there so i need to replace it if any body can help i would greatly appreciate it. Thanks FrankC :banghead:
catback23
05-08-2005, 11:08 PM
You need a service manual
Knifeblade
05-09-2005, 03:04 AM
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0e/5d/01/0900823d800e5d01.jsp
Start here, dude, and if ya look R side of the page, it can show ya how to surf to the switch itself, if needed. I highly recommend you register for this site , [freebie], saves all kinds of head-scratching, lol.
Regards
EZFrank
05-09-2005, 05:33 PM
Hey guys thanks for the quick reply and knifeblade03 thanks for the link to auto zone site that really helped me out alot you are the man brother. Thanks FrankC
evansdad
05-09-2005, 07:22 PM
tell you an easier way, well i think it is, if the key wont turn, then you gonna have to use a drill. i have a 00 cavy and the lock cylinder went out, the tumblers, and i had to use a drill to get it out instead of taking the column apart. just get some good bits and it takes about an hour, but once you get the tumblers drilled out the lock cylinder will turn. then put it in the on position and there is a little pin you have to push it in and then the lock cylinder will come out. when replacing with the new one just do the same thing. put the lock cylinder in the on position and slid it in. you will have to push the pin in. hope this helps. if you have to get a new lock cylinder you are better off going to the junkyard.
evansdad
05-09-2005, 07:29 PM
oh yeah and if you go to the junkyard and you cant find one with a key just get the vin and take it to a dealer and they will cut you a new key for about $8.
EZFrank
05-09-2005, 09:20 PM
Hey guy thanks im goin to try that first cause im worried about pulling the air bag out and blowing in my face, guys are great glad to be part of this forum. FrankC
Knifeblade
05-10-2005, 04:50 AM
evan has great thought regarding boneyard replace.
If ya follow the link's directions I gave ya, and disconnect the SIR, the bag can't blow.
EZFrank
05-10-2005, 11:32 AM
ok i will try that and follow the instructions. thanks again. will post back what happens when i am done. later frankc
evansdad
05-10-2005, 06:04 PM
yeah well the junkyard replaced worked fine on my 00 cavy and it was free. so think again.
EZFrank
05-10-2005, 06:52 PM
Yes im going to get it at the junk yard the switch that is but i was worried about the air bag but i finally read the link from auto zone and im goin to check it out if i think i cant doit then im goin to drill them out i really appreciate all the replys. again i thank you all.
evansdad
05-11-2005, 10:33 AM
ok glad i could help.
evansdad
05-11-2005, 10:37 AM
oh yeah if it comes to you having to drill it out, the black plastic cover on the lock cylinder go ahead and break it off then there should be a shiny piece of steel behind it. you wont be able to drill through this. you gonna have to get a flat head/straight screwdriver and place it in the slot in the middle and break it out. i have found the bigger the screwdriver the better and if you can use a craftsman in case the screwdriver breaks you can get a free replacement on it.
EZFrank
05-11-2005, 08:50 PM
evansdad i drilled it out today and i was able to start the car but keeps shuting off will stay on for like maybe 30 seconds and if i try to step on the gas it shuts down too. could it be the theft deterent is there a way to disable it. took maybe 5 minuts to drill it out i disconnected the battery and had no problems except know wont stay on. Thanks FrankC
evansdad
05-12-2005, 03:41 PM
does your car have the passlock or some sort of theft system. if so that is what it is. the dealer says to turn the key in the on position for 30 mins then turn the ignition off then start the car. it should be fine according to them, but it never worked on my 00 cavy, well the car still started and was driveable, but the theft system light was on. i just took it to the dealer and had them reset it. you can try this after you replace the lock cylinder. good luck let me know how it goes.
EZFrank
05-13-2005, 06:29 AM
the theft light is on but the key is a regular key dosent have the little chip in it. know i dont know if there is some other kind of deterent on these cars. Its driving me crazy LOL. Thanks FrankC
