B18 Swap with no spark COULD IT BE THE DIST?
Twyztidmind
05-06-2005, 06:45 PM
Ok i just got my swap done and i have fuel and compression but no spark. I have checked every last wire 4 or 5 times. How do i know if the dizzy is working or not? Could it be blown?
Also could i take the 90' B18 dizzy and put it on a 94 engine if i cut the plugs off and put the other ones on because i have a 90 dizzy sitting on a shelf.
IntegraB16
05-06-2005, 06:58 PM
I bet it is the coil. I would not even mess with that other distributor. It would probably just be a headach waiting to happen.
Twyztidmind
05-06-2005, 08:05 PM
it doest have a coil its inside the dizzy
civickiller
05-06-2005, 08:36 PM
uhh, yes it does have a coil, its inside the dist. you better reread what you just wrote.
ok so i bet you had a dx and did the mpfi swap, but because your trying to run a 94 dist, i hope you have switched it to obd1. then lastly, try and switch the 2 white wires on the dist and see if that fixes your problem
Twyztidmind
05-06-2005, 08:38 PM
UPDATE:::: Ok i took the dist. off and there is no ignition chip!! Some one must have stolen it or took it out or something. Anyways I want to get this car runnin ASAP and auto zone wants $175 for the ignition module!! I have a Dist. off of a 90 integra is there a way to wire it in to the harness?
civickiller
05-06-2005, 08:39 PM
pull the ignitor out of your 90 teg dist and put it in the 94 teg dist. very simple
Twyztidmind
05-06-2005, 09:02 PM
I tried to do that but the ignition chips are 2 diffrent sizes. The obd0 wont fit down in the obd1 hole. Sorry about the other post i miss read what you put.
civickiller
05-06-2005, 09:09 PM
go buy a new ignitor then
jeef
05-06-2005, 09:32 PM
or find a junk yard with a dizzy
