Lube in 2004 Taco DC transfer case?
shortlid
05-06-2005, 10:42 AM
What weight and GL-? is in the diffs and (Push-button) Transfer Case in a '04 Tacoma DC V6 4WD? What is the recommended fluid and change interval?
Brian R.
05-06-2005, 01:09 PM
From the AMSOIL website:
2004 TOYOTA TACOMA 3.4L 6-cyl VIN Code 8 5VZ-FE
FILTERS
Oil Filter......SDF57
Oil Vapor Filter......N/R
Air Filter......TS115
Fuel Filter......GF219
Fuel Vapor Filter......N/R
Trans......TF171
CHASSIS LUBRICATION
Four-wheel drive
8 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Two-wheel drive
0 Fittings, 0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL-7500 Synthetic Motor Oil
All Temps......5W-30
Manual Transmission,.....GL-5
All temps......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,.....GL-4
Gear Oil, API Service GL-4
Automatic Transmission.....TIV[1]
Synthetic Automatic Transmission Fluid
Differential, Front .....GL-5
75W-90
Severe Gear 75W-90
Differential, Rear .....GL-5
Above -18°C......90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
Transfer Case,.....GL-4
75W-90
Severe Gear 75W-90
Transfer Case,.....GL-5
75W-90
Severe Gear 75W-90
Fluids
Power Steering Fluid.....AF3
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3
Clutch Fluid.....HB
1. TIV is ATF Type T-IV, Toyota part no. 08886-01705.
CAPACITIES
Engine, 2WDwith filter..........5.7 quarts[1]
Engine, 4WDwith filter..........5.5 quarts[1]
Cooling System, W/ MT 4WD Initial Fill..........11.0 quarts
Cooling System, W/ MT 2WD Initial Fill..........10.0 quarts
Cooling System, W/ AT 4WD Initial Fill..........11.0 quarts
Automatic Transmission, 2WD Initial Fill..........2.1 quarts[2]
Automatic Transmission, 4WD Initial Fill..........2.1 quarts[2]
Automatic Transmission, Total Fill
A44D..........6.9 quarts
Differential, 2WD Ex Pre runer Rear..........5.5 pints
Differential, 4WD Ex Pre runer Front..........2.5 pints
Differential, Short wb with Cs Rear..........5.7 pints
Differential, Short wb witho Cs Rear..........5.5 pints
Differential, Ex long wb with Cs Rear..........6.3 pints
Differential, Ex long wb witho Cs Rear..........5.3 pints
Transfer Case,Std..........2.1 pints
1. After refill check oil level
2. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Transfer case
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
Manual Transmission
Brian R.
05-06-2005, 01:17 PM
Transfer Case - 60k
Differentials - 15K
shortlid
Thanks lots of info there. Do you guys recomend GL-4 or GL-5 for teh transfer case. I know some manual tranny's can't have GL_5 casue it attacks soft metals!! Is there any thing like a syncro in the push-button '04 Transfer case mated to the AT?? For someone who does not tow or go off roading GL-5 75W-90 syn. gear lube in both front and rear right. A '04 DC Taco with the V6 and automatic does not have a limited slip rear end right??
shortlid
05-06-2005, 01:18 PM
Transfer Case - 60k
Differentials - 15K
Cool, do I have to take the front skid plate off teh '04 DC to get to teh front diff?
Brian R.
05-06-2005, 01:23 PM
Never seen one, but I would bet alot the answer is yes. Protecting the differential is one of the functions of the skid plate.
As far as what gear lube to use in the transfer case, go with what AMSOIL recommends (either one: GL-4 or GL-5).
shortlid
05-09-2005, 11:37 AM
I am guessing that all Double Cabs are "Ex Long WB"? Also what is with/with out Cs??
Brian R.
05-09-2005, 01:25 PM
I don't know off-hand (locking differential?), but you really don't need to know. Just fill it until the gear lube runs out the fill hole and cap it up.
SEAN_at_TLT
05-09-2005, 08:31 PM
Technically Toyota recommends only filling to about ~10mm below the fill hole but I always fill until it overflows. If the diffs are overfilled they will just puke the excess out of the breather anyway. Good info Brian! :)
FWIW I run Redline GL-5 90wt in my diffs and x-fer case as well as manual trans.
Also FWIW API stands for the Automotive Petroleum Institute.
Brian R.
05-09-2005, 10:31 PM
Toyota specifies that the transfer case and differentials in my truck are to be filled within 5 mm of the bottom of the fill hole.
groupset
05-11-2005, 11:20 PM
You have to take off both skid plates underneath in order to access the front diff. You'll need a 10mm hex bit for the front diff, and a 24mm socket for the center diff and rear axle. Here's a link with some pictures, also:
http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep4.html#diff
I just finished replacing all these fluids on my '03 DC 4x4 with Mobil 1 75W-90 synthetic gear lube; easy enough job but a little messy. About 22K miles on mine, the front and center fluid was fairly clean when it came out; I was quite surprised at how nasty the rear fluid looked. Glad I changed it.
SEAN_at_TLT
05-12-2005, 12:48 AM
You have to take off both skid plates underneath in order to access the front diff. You'll need a 10mm hex bit for the front diff, and a 24mm socket for the center diff and rear axle....
....About 22K miles on mine, the front and center fluid was fairly clean when it came out; I was quite surprised at how nasty the rear fluid looked. Glad I changed it.
I highly recommend using a 6-sided 24mm socket as a 12-sided will tend to round the head of the drain plug. I bought a Snap-On 24mm just for this. I also ground the face of it completely flat to get a better purchase on the shallow head of the drain plug. Almost every used Toyota I've bought had stripped drain plug heads. I once spent about half a day dremeling the drain plug heads down to a smaller size on one particular truck of ours becasue some toolbox jacked them up so bad.
The reason you rear diff fluid was so bad is because the gears went through their break-in period and since the rear is always engaged it has the most run time on it.
