Side mirror still doenst work
jedimaster26
05-05-2005, 10:15 AM
Two of the functions still dont work. Right and down.
The others do. 1993 tbird
Any ideas?
Any ideas?
viper_e2000
05-06-2005, 03:39 AM
open the door and pop out the black lid in the coner with a flat head screw driver then pull out the wire and make sure that all three wires are connected.
jake ash
05-07-2005, 09:06 PM
theres a solder path inside the switch that is broken
viper_e2000
05-09-2005, 05:57 AM
if your switch is broken then you neek to replace the switch, that would be alot easier, just go to a junk yard and find another switch with the wires and replace the old switch. When you replace the switch make sure that the wires from the new switch match with the wires of the old switch and it should work. I just fixed my side mirror also.
