b16 map sensor broke, probably during shipping. Where can i purchase one?
jlshondacrx90
05-03-2005, 10:37 PM
My map sensor, i think that it is on my b16 is broken, probably due to shipping, do i have to get one on ebay or can i order one from a dealership? thanks
johnb16a2
05-03-2005, 10:58 PM
Yup, your best bet is the dealer. However, think that part is VERY expensive. Your other option try to find one in the junkyard. I believe most SOHC Civics and Del Sols used the same part number. GL
EF You
05-03-2005, 11:00 PM
dude, it might not be the map sensor. the map sensor on older civics and integras is located on the firewall, not on the engine. and it has a vacuum hose running to it. you probably have a broken throttle position sensor, aka TPS. its on the throttle body of the engine and usually gets broken during shipping.
jlshondacrx90
05-03-2005, 11:01 PM
alright, thanks
jlshondacrx90
05-03-2005, 11:02 PM
well if i were to get one at a dealership what year of the vehicle would i look up for that then? 94-97 del sol? 88-95 civic/ crx?
jlshondacrx90
05-03-2005, 11:12 PM
yeah its the tps sensor, can i get the replaced at a dealership? or do i gotta go to ebay or a junkyard?
travagliante
05-04-2005, 12:46 AM
You have to get a whole new throttle body if you go to the dealer. Just get any 86+Acura or 88+ honda TPS sensor at the junkyard and cut the rivets off and screw the new one on!
