compression ratio
EOD AIRFORCE
05-02-2005, 01:21 PM
Hey fellas. Can anybody explain how compression ratios play into performance, gas mileage, power? Thanks
Link85x
05-02-2005, 01:26 PM
Also, how do you check your compression ratios?
Dober89
05-02-2005, 05:31 PM
Usually the higher compression, the more power you get. You also need to use better grade fuel or you will get detonation and things will go boom.
CamarosRsweet94
05-03-2005, 12:43 AM
You can have a leakdown test done, but if you just want to know what your car has stock, look in the manual...
cooltc2004
05-03-2005, 01:14 PM
The higher the compression, the higher octain gas you need to use, and usually the more power you gain, as well as the gas you use =P
96Civ
05-03-2005, 02:31 PM
compression also has a lot to do with the life of the engine. More compression and your motor won't last as long until it needs a rebuild again. Less compression and it will last longer than a honda.
CamarosRsweet94
05-03-2005, 11:50 PM
Yeah, and it will have less power too...
96Civ
05-03-2005, 11:57 PM
No doubt... its purely choice. Frankly I would go high compression and rebuild after 100k just to be safe.
CamarosRsweet94
05-04-2005, 12:03 AM
No point in rebuilding until the engine is running poorly, otherwise you are fixing stuff that ain't broke. If you take good care of the engine and don't beat it like a rented mule it will last way more than 100k. Just keep the coolant and oil full and clean and it'll be good for a while.
96Civ
05-04-2005, 01:25 AM
Your right... but still I wouldn't wait too long. I have this everlasting fear of a rod breaking and punching a hole in the engine. :sly:
CamarosRsweet94
05-04-2005, 09:50 AM
yeah, I agree a rod making a hole in the block would be a pretty bad thing.
