Wrecked my baby
poormillionaire2
05-02-2005, 08:58 AM
I was coming home from school on Friday after it rained. I was in my subdivision coming out of a small bend in the road and I either hit an oil spot on the road or I hit the accelerator too soon, but I started to slide. So I counter-steered but overcorrected, so my car spun 180 and swung the back-left rear tire into a sewer drain. So anyway, there really isn't any body damage, its all internal.
So, the tire is angled inward, the brake/rotor needs to be replaced, the axle is pushed to the right, and the tranny (A4) is really hard to shift and doesn't have reverse. And when I put it in the neutral slot, its actually in drive. I think its because the driveshaft is angled now. I also bent part of the frame (but I think someone called it a follower...but is replaceable).
I am a pessimistic and I assume the worst, and I don't want to total my car. So, do you think some of these things aren't as bad as I think they are or should I start looking for a cheap car? I only have about $3K for repairs, but that's even a stretch. I have been in a bad mood ever since. Someone please tell its not as bad as I think it is.
LT1MAN
05-02-2005, 09:39 AM
well if you try to claim in on insurance most likely they will total it if there is any kind of frame damage. (even tho its not really a frame). i would say you could get someone to custom fab something to fix it rather than junk your car. they dont pay too much for wrecked lt1's.
Savage Messiah
05-02-2005, 10:41 AM
New rear end, prolly 2-300 bucks... talk to a trany shop about your trans i dont know if a bent driveshaft would cause that then again I dont know too much about trannys, and see how damaged that frame part is
