New Fuel Pump Relay
winstonusmc
05-01-2005, 11:39 PM
I am so amazed on how much the wiring sucks on the S13's fuel pump. I started having problems with my car last week when I put the Walbro 255lph HP pump in my car. I thought that the pump was bad or something. I then checked the voltage, a horrible 10.8v. Today was the big day, it was hot, almost 100 or so. The car was driving like a big turd. I guess the wire has much higher resistance in the heat. I went to Autozone and invested in a relay, 14g wire, and some connectors. I totally removed the stock relay and ran all new wire from front to back. I check the voltage again, 12.8v. The pump was singing nice and clean too. Took her for a drive and ran the piss out of it. Hope it drives better now.
mynismo
05-02-2005, 07:32 AM
yes this is the first thing we do on turbo upgraded cars..
you could have also just spliced into the wiring in the back, would have been a hell of a lot easier. run a relay with a splice so power goes directly to battery (inline fuse), works good if you have the battery in the back.
winstonusmc
05-02-2005, 09:48 AM
I like the cleaner look. I will take the extra 20 minutes to make it a little more organized. Only took me 30 minutes anyway.
nissanfanatic
05-02-2005, 07:30 PM
Yea I agree. Should prolly use at least 12g wire too. Soldering is a huge plus and looks much better along with heat shrink tubing. I ran 10g wire along with a 30a fuse. Ran full 10g from the battery-to-fuse-to-relay-to-pump. I was seeing some 13s past 5k and now I run a solid 12:1AF.
Nice job though. Great cheap upgrade. Gotta love them.
