wierd engine problem
Cbballplaya
04-28-2005, 08:51 AM
I have a 89 RS with the 305 and a 5 spd manual... Sometimes when im driving my check engine light flashes and the car starts to hesitate and shake(feels like you are tapping the gas pedal). I ran the car for codes with our diagnostic machine and it doesn't show anything. I replaced the cap and rotor, plugs, plug wires, and the O2 sensor but it still does it.
It only does this though after I've been driving for like 5 or 10 minutes but other times it won't do it at all.
Dan89rs
04-28-2005, 09:00 PM
i cant help much but id recommend a new air and fuel filter. it did wonders to my car. try getting sum codes off of it again. i would think sumthing would show up if the ses light is on. good luck.
Cbballplaya
04-29-2005, 01:23 PM
alright...i'll try the air filter, i already did the fuel filter...forgot to mention it before...but i'll try the air filter and i'll let you know what happens
ct91rs
04-29-2005, 01:34 PM
Are you sure there are no codes? I've never used a tester on an OBDI, but I have checked many for codes. They usually store a code whether the light is on constantly or intermittently.
Dan89rs
04-30-2005, 08:36 PM
thats what i wa sthinking, because my 32(egr) code doesnt always throw the ses light and the code will show up even with the light not on. and i think the air filter will help but u really need to get a code, so it'll pinpoint what it is.
Cbballplaya
05-05-2005, 07:41 AM
I hooked the car up to an actual diagnostics machine/scanner, im not just trying to flash the codes so i know that it's not giving me any codes
maybe something's wrong with the ecm?
Cbballplaya
05-12-2005, 08:37 AM
i replaced the air filter...no luck, same problem
Vortec350S10
05-16-2005, 01:07 AM
yeah the air filter isn't gonna fix it. If it only does it after it's warmed up, the problem is happening when the ECM is in closed loop- working of the O2 sensor. I don't know what it is, but it could be a different sensor. I'm guessing you got a TBI- it could be a intermitent fuel pump problem- rig up a T fitting on the fuel line before it goes in the throttle body and check your pressure. It should be in the 9-13 psi range. Obviously if its a intermittent problem it will probably read fine until your driving and it does it, which would be harder to check fuel pressure while driving... hope this helps a little
Cbballplaya
05-17-2005, 07:59 AM
thanks a lot...i'll try it out and i will let ya know what happens
