knock sensor??
riff22
04-27-2005, 05:14 PM
my pocketlogger says code p0325: knock sensor 1 circuit(bank1 or single sensor) does this mean knock? or do i need to replace a sensor or what? would this cause hesitation or a miss?
thanks
tyler
kjewer1
04-28-2005, 12:25 AM
Make sure the sensor is still plugged in, and make sure it is still attached to the block. But I have a feeling only a bad or disconnected sensor will trigger that DTC. Its definitely not because its simply reading too much knock or anything like that. They are around 50 bucks at the dealer.
riff22
04-28-2005, 07:40 AM
thanks 95gsxracer for all the help!!
riff22
04-28-2005, 09:57 AM
where is this sensor and what does it look like?
kjewer1
04-29-2005, 07:04 AM
Its on the back of the block between the 1 and 2 cylinder. The only sensor on that side of the motor. It has a hex on it, about 24-26 mm, with a pigtail coming off it (2 wire). It plugs into the harness right over the tranny. Be careful when installing the new one, the torque spec is around ~7 ft lbs despite its large size. Over torquing can make it over sensitive.
riff22
04-29-2005, 08:48 AM
if only i had his smarts, thanks kevin
riff22
05-09-2005, 10:26 AM
im going to check it for resistance does anybody know what it is suppost to be?
kjewer1
05-10-2005, 01:45 AM
I dont think a resistance test will tell you anything. I believe the sensor is a piezo-electric device.
riff22
05-10-2005, 07:56 AM
hmmm. is there anyway to check it? i know it makes a connection from the plug to the sensor, but im not sure about to the ecu or where ever the other end goes.
kjewer1
05-11-2005, 08:19 AM
If you want to check the wiring to the ECU, check the vfaq to see what pin it goes to. Ohm it out with a meter. There is no test you can do for the sensor itself.
riff22
05-11-2005, 09:55 AM
figured it out, my car has been running like shit for 2 months because of the wire to the ecu came unhooked... should have been the first thing i checked, duh!! i used butt connnectors when i installed my safc and it came undone. im going to solder and heat shrink them this weekend.
thanks for all the help kevin
riff22
05-11-2005, 09:56 AM
oh yea, i just unhooked the knock wire from the safc, it doesnt do anything anyways right?
spyderturbo007
05-11-2005, 11:09 AM
No, I wish it worked, but unfortunately it doesn't. :mad:
