computer help
jason-1995fbody
04-26-2005, 05:37 PM
1993 camero 3.4 ses light is on but when i put the jumper in the light will not flash car is also shakes while in gear
FormulaLT1
04-26-2005, 09:40 PM
Are you sure you had terminal A & B jumped and not B & C?. They are very close and often I hit the wrong one too. DId the fans kick on when you jumped it?
jason-1995fbody
04-27-2005, 12:25 PM
yes it the correct terminals and the fans come on but the fan dose not work when the car gets hot but if i turn the ac on it works
FormulaLT1
04-27-2005, 12:51 PM
When you ground the terminals. The fans are suppose to click on. Thats why I was asking. If they come on then its a ECM connection problem. and not a terminal problem.
jason-1995fbody
04-27-2005, 05:03 PM
what should i look for
FormulaLT1
04-27-2005, 05:51 PM
Just jump the terminal like before, turn the ignition on and listen to see if you hear the fans. If you don't pull the datalink terminal and see if one of the wires behind it is disconnected or damaged.
jason-1995fbody
04-27-2005, 06:55 PM
no wire damage under dash or under hood the thing that is strange to me is i pulled the chip out of the computer and the car runs the same as with it in (this was just a way to play but it was strange)
