1990 Cruise light blinking codes???
gofission
04-26-2005, 04:57 AM
While driving, I held down the Coast/Set button then pushed the left power on buttion. The CRUISE Light started flashing some type of code. The codes changed depending wheither I was accelerating, coasting or sitting at a traffic light. Any idea what this means?
Brian R.
04-26-2005, 01:19 PM
Check the connector to the CC actuator. Clean it and make sure it is making a tight connection.
Brian R.
If the CC isn't working, check the connector to the CC actuator. Clean it and make sure it is making a tight connection.
If it's working, must be aliens
gofission
04-26-2005, 09:12 PM
The cruise control works fine.
Brian R.
04-26-2005, 10:30 PM
Definitely aliens then...
