92 chevy van 5.0 bad surging at idle and highway
HandyRandyfl
04-25-2005, 09:10 PM
Need help no power at take off bad surging. Replaced O2 Senser, Map Sensor, EGR Valve, Hei Module, Ingnition Coil, Pluggs , Wires, cap, rotor, fuel filter air filter, pcv valve, cat. Check all vac hoses . checked fuel pressure between speeks . check timing. check throttle body for leaks . running out of thoughts . any suggestions will be very helpful
smokey041369
05-04-2005, 10:36 AM
goto the auto parts store and have them put the code reader on it
if it doesn't tell on the print out what the codes mean post them here and we can help you more
