2002 5.3l Z71 Oil Capacity
doc5339
04-23-2005, 04:34 PM
The manual says that my Ext. Cab Z71's oil capacity is 6 quarts, my old 96 2dr Tahoe 4X4 had a 5.7L, and only took 5 quarts? Seems like alot of oil?
How much do you guys put in your 5.3 Vortecs?
Thanks in advance.
Thanks in advance.
airtight_python
04-23-2005, 05:01 PM
If the manual says 6 quarts, 6 quarts is probably right. Even if it's a little over it wouldn't hurt anything.
Jason Shrader
04-23-2005, 06:27 PM
Thanks in advance.
My 2003 Z71 5.3L takes 6 qts.. Just make sure it's at the full line on your dipstick each time.
Thanks in advance.
rustcal
04-23-2005, 07:16 PM
some manuals say 5 quarts but they have the little "*" and somewhere else it says to add 1 quart if you change the oil filter. my ex missed that in her manual and almost fried her engine cuz of it.
busta
04-23-2005, 10:54 PM
ya mine take's a full 6 bottle's of ROYAL PURPLE!!!!
steelieagw81
04-24-2005, 08:24 AM
My 99' takes just a hair under 6.5 qts of mobil-1
Donor22
04-24-2005, 01:00 PM
I also have a 2002 Z71 ext. 5.3L. It indeed takes six full quarts according to both the dipstick (after pouring the first 5 qts) and the Haynes manual specs. Obviously, you're changing the filter, right? If you want to be sure, fill it with five quarts, run the engine, then check it again (also a good time to check for leaks). You should see that you need to add another quart.
BTW: My dad drives a Volvo S70 5-cyl. which also takes a full six quarts despite the smaller engine.
