Yup, another turboing an N/A Q...
RSLaser
04-22-2005, 08:38 AM
I've been readnig up at VFAQ for months and months about turboing the Laser i have. The main problem i can see with even using the na block is the amount of piston knock...cause by the shitty placement of the rings? My Q is I was planning on boring it out twenty over, and, would the type of piston i use (diferent ring placement) eliminate the problem?
Cause ive got this huge Holset HX55 turbo just sitting in my room collecting dust.
gstKillerRed07
04-23-2005, 11:58 PM
just make sure u'r bottom end is good, the pistons...you should be ok on stock...but if u want to spoon it...go for it!
