Help!!
Ghost-CAVy
04-21-2005, 01:22 PM
damn i know i write on here alot but ....now im loosing power almost by the day and i cant figure out whats wrong...no engine lights or anything...scanned the chip on my car and it says everything is fine...and i cant see any visible signs of a cause...im wondering if it could be something like a vacuum leak or something along those lines or maybe my fuel pump but i dont want to replace or get every single thing checked out cuz i dont have the time , money , and patience to do something like that....so if someone could help me out that would be awesome. thx
jayson716
04-21-2005, 05:01 PM
well the map sensor could be a problem. if there is a hole in the hose coming out of the map sensor you will have power loss. and will not get a Check Engine light. but other than the normal change plugs wires and oil and filter... then i would start with map sensors and vacuum leaks.
Classicrocjunkie
04-21-2005, 09:31 PM
Maybe fuel injector cleaning at dealership too... air filter as well. THere is alot of pollen in the air this time of year.
Ghost-CAVy
04-22-2005, 09:01 AM
well ive got an air intake cone filter and i just cleaned that like 4 days ago with still no improvement , i put bosh plat 4 plugs in right before winter , and im about 2500 kilometers from my next oil change with full dipstick reading....where is the map sensor on a cavalier tho...ill check that out for sure .
Classicrocjunkie
04-22-2005, 09:27 AM
...i put bosh plat 4 plugs in right before winter
Those plugs are crap... they do more harm than good, and totally defeat their intended purpose. Go and get the AC delco plats or NGK Iridium.
public
04-22-2005, 10:41 AM
DITTO, This could very well be your problem.
