creaky noise - front passenger side
tricky
04-19-2005, 06:57 AM
there is a creaky noise coming from the front right passenger side...i got my control arms changed 6 months ago...so it's not them....it creaky's when l go over bumps or coming to a stop...could it be my shocks or coil springs....if so is it expensive to fix...
hdnorm2
05-04-2005, 07:44 PM
did you replace all 4 control arms there is a recall open on certain model year a-4.. also chek your tie-rod ends and your upper inks...i have never seen shocks or coils make a creaking noise
TudorDrancea
05-20-2005, 06:50 PM
I have the same problem too what it is is the rubber boot on the axle they break and rub the metal
MikeLee2484
05-21-2005, 01:28 AM
the boot is the cv boot i believe. i brought mine in for that recall for the upper control arms and told me i needed to replace the lower control arm and the cv boot on the front drivers side, there was something else i cant remember right now but ill post if i find the paper work. anyway, i have a creak in the steering so i dont know the cv boot would be related to that or not.
