Axle/Tranny leak?
slayme01
04-17-2005, 05:31 PM
I have a small leak coming from my tranny(i think)
It's where the axle connects to it,the fluid is pinkish in color.
what could that be?(not an expert here if you can't tell already)
91 CRX Si 5spd
johnb16a2
04-17-2005, 07:21 PM
Hope that it's not automatic transmission fluid. Your car's manual tranny should have motor oil or Honda manual transmission oil. But the seal is replaceable but you have to take the axle out to do it. GL
CR50HC
04-17-2005, 10:18 PM
Is your tranny "overfilled"?
Jos4DCivic
04-17-2005, 11:06 PM
could also be rear main seal. had the same problem B4 and it turned out the RMS was ripped and the input shaft was not aligned correctly and cause tranny to leak(rebuilt tranny).leakage cuased it to look like it was coming from axle seal though because it dripped down. if axle seal,not all hard to replace. just got to take cv-axle out an remove it. But pinkish color i :dunno:. unless you filled tranny with ATF as stated B4. like CR50HC said " you sure you didnt over fill tranny?". should take about 1.8 quarts.
GL
Ones&zeros
04-18-2005, 09:16 PM
axel seal,, need to replace,,you'll need to pry the axle seal using a flat head screwe driver.
