bleed clutch
beatdown944
04-16-2005, 05:06 PM
for clarification sake, can somebody direct me to where exactly I bleed the clutch system. I searched and came up with "under the motor" "front" "by the trans" I found a bleeder screw to the front of the motor, in the center by the front engine mount, left of the exhaust man(driver seat view) around where the oil drainback pipe is for the turbo. Am I right?
beatdown944
04-16-2005, 05:27 PM
I read on the talon digest to get a bleeder screw(the one with the check valve that closes automatically), this would make this one man mission possible. the size listed was a 10mm x 1.0. this size was for a 91 talon though, anybody know if the 2g has the same size bleeder?
riff22
04-16-2005, 06:53 PM
i bleed mine with a 10 mm wrench its on your slave cylinder, cant miss it looks like a greese fitting..
beatdown944
04-16-2005, 09:32 PM
is the slave cylinder the one by the master on the firewall filled with fluid? if so, there is no fitting there. there is a fitting by the front of the motor on the trans. is it or is it not this fitting? am I in the completely wrong place?
riff22
04-17-2005, 04:34 PM
its on your tranny under the car 10m, just have some one pump your petal then have them hold it and crack the line, dont let up on the petal till you have the line tight or it will suck air in.
