Will the B18 BLOW?
Twyztidmind
04-16-2005, 12:34 AM
Hey, i just got a B18 LS engine out of a 94 teg with 52K miles. I am planning on turboing it. Can i keep the stock interneals are will it blow. I am not planning on running a huge amount of boost just around 8-10 PSI. If not what will i have to buy to make it last?
civickiller
04-16-2005, 02:55 AM
actually at 8-10ps is only around mid 200whp. your block can take that, just get it tuned good. but if you have the extra money and want insurance then get pistons because ringlands are the weak link
BLU CIVIC
04-16-2005, 09:20 AM
yeas...improper or lack of tuning will lead to detonation...but it is in ur best intrest to build up the motor while it is out...turboing, done right, isn't cheap but well worth the extra $$$
doug294
04-16-2005, 09:48 AM
I agree, while it's out go ahead and build it.
CBURKE
04-16-2005, 10:34 AM
You will be fine as long as you stay below that 10psi mark.
doug294
04-16-2005, 10:43 AM
But you know how boost is addicting.
BLU CIVIC
04-16-2005, 11:17 AM
:lol: was about to say the same thing...u know he'll turn up the boost to race someone then next thing u know :crying:
1PhatCX
04-16-2005, 12:50 PM
thats the whole reason i wanna build the bottom end of my ZC before i bolt the turbo on :D just incase u know hehe
SiZ
04-16-2005, 02:03 PM
:swear: Kinda a vague statment wouldn't you say?! You could easily blow your motor boosting 10psi!
civickiller
04-16-2005, 02:26 PM
actually on a stock ls, i find most people hit the 300whp mark at around 14psi. but also is a vague statement depending on the turbo he is using.
doug294
04-16-2005, 02:36 PM
Yeah I too have seen/heard of some good numbers on stock LS motors. Then again the people also did some really good tunning. Also like CivicKiller said a small turbo at 10 psi and a big turbo at 10psi are really different so it depends on what turbo he is using.
SiZ
04-16-2005, 06:17 PM
And even moreso on the fuel and spark managment. ;)
BiGwiLLswiLLy
04-16-2005, 06:42 PM
jus make sure ur able to keep up the fuel demand cause most of the time motors blow on a turbo is it runs to lean....
BiGwiLLswiLLy
04-16-2005, 06:43 PM
also dont forget while its out the timing belt water pump n all that good stuff...
Twyztidmind
04-17-2005, 11:09 AM
cool, so if i get like a greddy blue box FMU would that be considered good tuning?
